Yalemaier
Thank you very much!Found photos with ECF 275/35/18
hi. with 5mm, stock bolt was at borderline and wanted to replace it with slightly longer one. later, I opted to APEX stud kit. it came with everything you need including thread locker. Also, the lug nuts were much lighter than expected.Hi Nibble, did you have to get longer bolts to use with the Apex 5mm spacers? If so, where would you recommend a good set? Thanks!
I know Nibble already responded to this, but I did want to chime in.Hi Nibble, did you have to get longer bolts to use with the Apex 5mm spacers? If so, where would you recommend a good set? Thanks!
