Spart
- Thread starter
- #1
In all my research, it sure seems like a lot of the exhausts out there (for the 3.0) seem to repeat some of the same patterns:
I'm coming to the Supra from five years of GT350 ownership with the factory active exhaust, which really has me spoiled. With the valves closed on that car, it's almost as quiet as the Supra is. Valves open, it's a party but it won't blow your eardrums out. Very Jekyll and Hyde - perfect!
I should mention that I have pretty much ruled out a downpipe, I'm not interested in more power and I also don't really want to play games with the warranty. I'll likely get an extended warranty soon as I'm considering keeping this car for quite a while.
Also, whatever I get has to be compatible with the manual trans. If not now, then something hopefully in the works. I've conversed back and forth with aFe a little bit and it seems like an option for MT cars will be in the works once they can get their hands on one in CA.
- They take you from a very quiet OEM setup to a very loud aftermarket one, with not much in-between.
- They omit the OEM valve, or if they do keep it...
- ..there's not a ton of difference between valve open and valve closed.
