When you disengage the clutch in neutral a couple of things happen. The crankshaft is loaded from the clutch pedal force and and the crank thrust bearing is now loaded. This is something you won't normally feel though. The main thing is there is a 3 pound clutch friction plate that's now stationary instead of rotating at engine rpm and the crank pilot bearing if it has one that supports the gearbox input shaft is rotating because the gearbox input shaft has stopped turning. So an Eagle arsed owner may feel slight differences in the Idle. Some cars have an Anti stall strategy where the ECU ups the engine speed without throttle input as you release the clutch also. The most common thing that's usually noticeable to the attuned person is generally the NVH and noise is reduced when you disengage the clutch due to the friction pate and gearbox now being stationary or very close to stationary. Those big gears in the gearbox designed to take 600ft/lbs or so of torque have mass and backlash and usually rumble away a little at idle with the clutch engaged and quiten down when you depress the clutch pedal as the gearbox stops rotating. More noticeable on a larger capacity 4 cylinder engine with inherently imperfect secondary balance. Not so much on an in line 6 with perfect primary and secondary balance.Can I ask please while we're on this topic so I don't open a new thread:
Can someone explain why the engine sound idling changes ever so slightly, (you can also feel the change in vibration in the cabin it very subtly) when you put the clutch in whilst in neutral?
No other manual car I drove does this, is it something to do with the software for the rev matching?
To be clear, this isn't an issue, it feels like that's how the car is designed to work but I'm curious to understand the mechanical reason(s) why.
