The call system module is in the center of the car between the subwoofers.Checking if anyone knows the battery part number and location in the vehicle for the emergency call system module. Thanks in advance.
Hello,Good Day,
I know this might not be the right topic for what am I asking for but since it has pictures that i feel relative to my question I'm going to ask here,
So my car didn't come equipped with Apple Carplay from the dealer, but I got it installed by a guy who is expert in BMWs, he updated the firmware i think,
however, I'm having an issue with the wireless connectivity, it is very weak signal and I need to keep the phone in one of the cup holders otherwise Carplay will disconnect.
The guy recommended installing / changing the Wifi antenna and I have no idea where that thing is located ?
" He said that this is common with BMWs that doesn't have carplay equipped from the dealer",
and he recommended this antenna:
https://ebay.us/x4ajSe
Kindly guide me where can I find the place of the antenna ?
and whether this antenna is good or not ?
Thanks in advance.
How often do you/we need to replace this battery? My emergency battery needs to be replaced on my 2020 Launch Edition. They say its on back ordered for the last 2 months. Anyone else had similar failures, impacts on performance, and feedback? ThanksThe call system module is in the center of the car between the subwoofers.
Here is the top of the modem.
Here's the battery:
Good question..does it give a warning sound? display?How often do you/we need to replace this battery? My emergency battery needs to be replaced on my 2020 Launch Edition. They say its on back ordered for the last 2 months. Anyone else had similar failures, impacts on performance, and feedback? Thanks
I pulled mine out
Just pulled battery out of it. I have like 6 warnings that pop up each time I start. Track car. So not really concernedhow did you do it?
or do you mean you didn't uncode it and just pulled out? do you still have a warning on the dash?
Anyone?? the "Emergency Call System Malfunction' is driving me nuts, Wanted to check before I replaced battery.Is there a way to uncode the sos?
