Wider front tires - tramlining?
White Shadow
Thomas
NJ
Audi, Jeep
For anyone with wider than stock tires, are you experiencing any tramlining? It seems that the popluar front tires size is only marginally wider (255 vs 265 tread width), so I'm thinking that this isn't an issue, but I'm still wondering because I've had this issue on past cars and it would be nice to know if the Supra is susceptbile to tramlining with wider tires.
dzeleski
Dylan
LI, NY
2022 Supra, 2017 Tacoma
I run 275 fronts and have very little tramlining. I have a great alignment though which has a big impact. If you can find someone that truly knows how to setup a car you wont have very much with this platform at least in my experience.
Evolution
Sean
21 Supra
I probably run the widest front tires out of most of you (315s) and have a pretty aggressive alignment. My car does tramline a bit but it's not bad. I honestly think it has more to do with the amount of camber I run over how wide the tires are.
AJRMKV
2023 Manual Supra
I've experienced pretty bad tramlining with my supra since day one. At first I thought it was an alignment issue, so i got that done.. Still tramlines pretty hard. It's a 23
GreyMadder
WIlliamsburg, VA
No real issue and have swapped wheels with no alignment as of yet 275 with 305 in the rear
