DIY Clutch Delay Valve (CDV) Removal
94boosted
GR Supra MT, MK8 Golf R MT
Spart
2023 A91-MT
Yes I know, instead of swapping out the slave I was just going to do the mod in the OP's first post. But, I'd like to know what the part number is for the OEM slave, if anything ever happened to the driveline I'd certainly be swapping an OEM slave in prior to any warranty work.
That would be a waste of time and I expect the Toyota one may be harder to find and/or more expensive.
That referenced part number is literally identical to the OEM one in every visible way but for the presence of the delay valve just inside the hydraulic connection.
I purchased mine from FCP Euro and installed it myself. I kept my OEM slave cylinder for the same reason: to reinstall should I ever need to take the car in for warranty work on the transmission.
ApexTheory
Ontario
'23 GR Supra 3.0 Premium MT
I don't think you even need the spare part. You can just keep the spacer and CDV and re-install it easier than changing out the whole slave cylinder.
Stvee
Stvee
Yeah there is no reason you can't reinstall the CDV if needed.
94boosted
Good to know, I was worried that with having to use a metal screw to remove the spacer and CDV it would cause some damage to one, or both, preventing them from being reused.
ApexTheory
Ontario
The screw is just useful to get a little bit of friction on the inside barrel of the spacer/valve. As long as you're not reaming it in there you won't do any damage.
meeko
Travis
Durham, NC
23’ Stratosphere Blue MT
Thank you for your write up!! After buying power bleeder, I got this done in about an hour like you mentioned. It took a 2 or 3 times to get the CDV out but it was easy! Great write up!
Spart
2023 A91-MT
That power bleeder will be clutch (in the second definition of the word) whenever you decide to change out the OE brake fluid for a more track-capable one.
If you have any thoughts of tracking, Castrol SRF, Motul RBF, or Endless brake fluids are all really decent.
Turbro
Somewhere USA
24 Strat 3.0 MT, 94 Supra TT 6Spd
Did you get the European power bleeder? I see a lot of models of power bleeders, so i am curious
Chong
Eric
Philly
2023 3.0 MT
I'm not who you directed your question towards, but Motive 0109 is the one that's compatible with our cars.
Turbro
Somewhere USA
Perfect info. Thanks guys
FlammasWRLD
IL
2001 NB Miata - 2024 Red 3.0 Premium MT - Ninja400
All I can say is I wish I did this sooner. Completely fixed the weird clunky feel the gearbox had when trying to shift fast. I was experiencing small amounts of grind when doing WOT pulls during the 1-2 shift, and I haven't experienced it at all now after the CDV delete. I've had to re-learn how to drive the car smoothly.
When raising the car, be cautious about how high you lift it. This is important because there's a dividing wall in the master reservoir that separates the fluid for the brakes and the clutch. The clutch section only holds about 1-2 ounces of fluid. If the front of the car is lifted too high, it prevents the fluid from flowing back into the clutch section unless the reservoir is near overfilled.
Might've found this out the hard way... 😂
Thanks @Slybri for helping and letting me use your tools!
