Speedometer correction with Bimmercode?
Vertex
Vertex
Minnesota
22 3.0 Supra Matte Storm Gray
I tried to look around the forums a little and wasn't 100% certain if it was answered or if there was something thrown out in a thread somewhere on how to correct/alter the speedometer readout in these cars?
My biggest concern as some of you may not have thought about this is, with the speedometer actually being over by 2-3mph based off speed that means we will be accruing MORE miles on the car over time than we actually are traveling. I don't necessarily expect to have anything drastic happen after my 10yr warranty is up, however, just in case and also to more accurately have the correct mileage accruing on the speedometer I have an itch to fix this.
bushido
Miami
A90 Supra, N180 4Runner
Vertex
Vertex
Vertex
Minnesota
Bryan / Briana
Your moms bedsheets
How MPH is shown on the gauge cluster and how it is accumulated in KOMBI (for mileage) are two different things. KOMBI mileage goes off RAW speed, which is before any other gradients.
Vertex
Vertex
Vertex
Minnesota
If that's true then I don't really need to mess with it and honestly idk why I didn't think about how the board logic truly worked. Honestly thinking about it now that you bring that up, programming it won't even change that anyway :doh:
Joebednar4
Joe
Richmond, VA
Any idea if this regulates mileage shown on odometer as well? For those of us that changed tire size, mine is definitely off even more, lol. I was hoping somehow I could change it so it reads correctly, and doesn't add miles that aren't actually being added.
Bryan / Briana
Your moms bedsheets
Read my post above.
NINaudio
George
Illinois
2023 Supra 3.0 Premium
i3igpete
Chicago
2023 3.0L 8AT
STV3
Steve
2021 Toyota Supra 3.0 Premium
I was under the impression that this didn't work? It didn't seem to do anything for me.
I did this a long time ago and it worked somewhat. Now instead of showing 2-3 mph faster it only shows about 1 mph faster. Better than nothing.
BMWAF
www.instagram.com
Spart
2023 A91-MT
As mentioned by others, the stupid BMW speed correction deliberately shows you going faster than it truly knows you to be going, but records a more accurate mileage for the odometer.
This has been the case for a while because my 2011 JCW Mini was like this as well. I don't think we had Bimmercode in those days, so I put a size larger tire on it. Speedo fixed, but the odometer (and as a result, fuel economy stats) would underreport by 3% or whatever. Worthwhile tradeoff.
Main → Instrument Cluster (DKOMBI2) + [Expert] → 3000 ANZENGE_KONFIGURATION → BC_V_KORREKTUR → ohne_korrecktur
https://www.supramkv.com/threads/speedometer-is-not-accurate-23-a90.16437/post-253592
This setting removes some, but not all, of the speedometer error with OEM tires.
BMWAF
www.instagram.com
I'm pretty sure all car brands do this, not just beemers.
Spart
2023 A91-MT
My Fords were pretty close to dead-nuts on.
All three BMW products I've ever owned were by far the worst. It's sooo bad from the factory.
