Vibrations/Rattles in 2020 Premium Supra
nosavingthrow
Seattle, WA
^^^ Nice do you have a link for silicone clip cover?
Not the OP, but I assume this is what they bought https://www.ebay.com/itm/294535736276
Would keep the plastic of the buckle from banging against the trim when the seatbelt isn't in use. I usually just lean over and flip it so it stops rattling, but might try this out.
Andrew__a90
Andrew
Richmond, Virginia
2023 Supra 3.0 Premium Nitro Yellow
Another vibration spot located and eliminated...
I noticed lately that there was a vibration coming from the back of the center display even with no music playing ...While it's not as loud or obvious while driving with the music turned off, when play music at ~ 40% volume, the top grill plate of the center speaker cover will vibrate and rattle...The vibration from the grill cover would also travel to the display itself and cause this to vibrate as well...
I simply removed the plastic cover and noticed the speaker metal grill cover tabs (8 of them) were not securely pressed against the plastic of the main cover itself...I then pressed them firmly against the plastic cover and this seemed to fix the problem...see pic below...
Also the 2 torx screws holding down the display itself (which are exposed after removing the cover) needed roughly a 1/2 turn to secure them firmly...
Side note: I'm noticing these minor vibrations and rattling occurring more during the extremely hot weather (~110F) we've been having lately here in AZ....Which I suppose should be no surprise because of the large coefficient of expansion of the plastic material some plastic panels with tighter tolerances begin to press and rub against one another...
Putting foam tape over the 8 tabs and across the plastic that touches the screen also helps a lot, I did this originally but they once again became loose so taping it down fixes that.
Jmanlevan
Jordan
Denver, CO
When I drive with the stereo off I have a little occasional buzz which sounds like itā€™s coming from the tiny tweeter speaker/plastic surround behind my drivers seat. Itā€™s super irritating because I can definitely notice it when all I wanna do is listen to the glorious sport mode sounds! Anybody got any fixes for this?
Andrew__a90
Andrew
Richmond, Virginia
Itā€™s hopeless, this car is plagued by rattles but most sports cars are, from Mustangs to McLarens their interiors typical suck. I have this loud buzzing sound that sounds like itā€™s coming from the rear of the car. It only appears at times and then it will vanish without a trace. I took the liberty to add weatherstripping to all the plastic bits that touch glass or other hard plastic but Iā€™m sure itā€™s only a matter of time before that sound haunts me again. Good luck man but as far as eliminating these sounds go itā€™s bleak, consider yourself lucky if this is the only sound you are cursed with.
alan7467
Alan
Parker, CO
I developed a really annoying rattle in my dead pedal after going over some super shitty roads yesterday. Haven't had a chance to pull it apart to look for the source. If I apply enough pressure to it the rattling stops completely.
Carbon0
Birmingham, AL
2020 supra
Oh I had a similar issue that I fixed. There is a plastic trim piece that is almost like a kick plate. The same piece on the passenger side that you need to remove to replace the cabin air filter. That piece on the driver side touches the dead pedal and is likely why pressing on the dead pedal makes it go away. I removed the trim piece and lined some felt tape on the edges where it would touch other plastic pieces and I also removed the weird plastic tabs and put felt tape on each side of it where the plastic washer and tab goes. That resolved it for me.
alan7467
Alan
Parker, CO
Thanks for that! I havenā€™t had the rattle lately, but will take a look at quieting that trim piece.
