Loss of power - (ECM). Once we were able to get briefly get power back to the car, I got the following codes: p0607, P1408, p1407, and p16db.
SmilinAssassin
Shawn
NC
2023 A91 MT
The only mods I have that have electrical interaction are taillights and F1 Style 4th break light/reverse light. I also use BimmerCode for auto sports mode, mirror tilt, and a few other mods.
I stopped at a restaurant and came back to no power and my wipers running. I had it towed back to the house and was able to get power back long enough to pull the codes, and it is back off again.
Any help is greatly appreciated.
SmilinAssassin
SmilinAssassin
Shawn
NC
2023 A91 MT
Power like battery power?
Correct. No power to the inside of the car. The only power was to the wipers and the alarm when entering the car with a valet key.
skyviper80
Lawrence
Cabot, AR
2018 WRX STI, 2020 GR Supra
All your codes are electrical from what I can find. If you know the battery is good then need to look for a bad connection somewhere.
SmilinAssassin
SmilinAssassin
Shawn
NC
2023 A91 MT
Thank you. Iā€™m going to be testing the battery tomorrow, and then the connections with the lights my son and I put in.
SmilinAssassin
SmilinAssassin
Shawn
NC
2023 A91 MT
Update: I put the battery on a trickle charger and then put it on the tender. I havenā€™t had any issues since, but Iā€™m not sure that Iā€™m out of the woods yet. One lesson learned is that the car goes on the tender every night from here forward if Iā€™m not driving it for a few days.
SmilinAssassin
SmilinAssassin
Shawn
NC
2023 A91 MT
Back to the same problem. It happened this time while in the garage connected to the tender. Iā€™m going to splice the wires in properly tomorrow and go from there.
Loco38SUP
I would double check the tail lights and 4th brake light wiring. Sounds like something isnā€™t right and draining your system.
-RJM
SmilinAssassin
SmilinAssassin
Shawn
NC
2023 A91 MT
-RJM
I just got a new 4th brake light in today. Iā€™m going to replace it Saturday.
SmilinAssassin
SmilinAssassin
Shawn
NC
2023 A91 MT
It isnā€™t the brake lightā€™s fault. We bent a prong on the install and used the vampire splicers. Iā€™m going to hard wire it in and be super careful connecting the plug.
SmilinAssassin
SmilinAssassin
Shawn
NC
2023 A91 MT
I just changed out the 4th brake light and began monitoring the battery, it is currently at 12.72 while off.
