KahnBB6
I found a couple of them after my post.
https://www.m3post.com/forums/showthread.php?t=737734
And this Autoweek article from 2001:
https://www.autoweek.com/news/a2122161/no-more-92-premium-octane-rating-drops-california/
High performance cars since 2001 are tuned by manufacturers on 91 octane fuel as a baseline with any higher octane fuel mapping modes/detection being additional.
Here is something Sport Compact Car magazine's Technobabble wrote back in 2001.
Quote:
By the time you read this, residents of Nevada and Arizona will have been screwed too. What, you don't live there? Just wait, you're next.
It's not like West Coasters haven't been screwed before. From roadside smog dynos to tickets for shiny mufflers, we're used to the man getting us down, but this time they're hitting us where we eat. This time they're taking our gas. We already have pretty crappy premium fuel in California. Just like most of the West Coast, we're stuck with 92 octane, while much of the Midwest and the East Coast got to play with 93 or better. Now, as of August 1, 2001, the best we can get is 91. Time to turn down the boost.
On the off chance you're only now trading in your Schwinn 10-speed on a twin-turbo Supra, I guess I should stop here and explain what octane is and how it affects your engine.
When fuel is injected into the cylinder, compressed and ignited, one of two things can happen. It either burns quickly and smoothly, shoving the piston down with a strong, even push, or it explodes all at once, releasing its energy in a sudden burst of heat and pressure. This explosion is called knocking or pinging, and it's something engineers like to call "really bad."
Knock is usually ill timed, occurring early in the combustion cycle when the crank and rod are still straight up or even worse, still trying to complete the compression stroke. As a result, all the energy released slams into the top of the piston without actually turning the crank. When this happens under stressful enough conditions--like, 20-psi of boost in a Miata--you start breaking things. Usually the ring lands; however, if your pistons are strong enough, you might get lucky and blow a head gasket.
Octane, for those of you still on the bike, is the rating of a fuel's ability to not do this. The higher the number, the less likely the fuel is to detonate. What this means to us, of course, is the higher the number, the more boost we can throw at that Miata. High-octane gas isn't just for tuners though. Plenty of stock cars depend on the stuff, including a Celica GT-S with its 11.5:1 compression, or a turbocharged WRX or Volkswagen 1.8T.
These cars rely on high-octane gas to keep from detonating. Feed them 91 octane and they won't start breaking things, because their knock sensors will see it coming and retard the timing, turn down the boost or otherwise reduce your chances of having any fun.
Whose fault is it this time, CARB? The EPA? The CHP? None of the above. This time we're being victimized partly by the oil companies, and partly--this is the one that hurts--by ourselves.
You see, when crude oil is refined into gasoline, the refinery doesn't have all that much control over what comes out. Crude oil is full of all kinds of stuff, and a refinery simply separates it, sorting all the iso-this and hepta-that in order of density. The really heavy stuff, like tar, is near the bottom, while the really light stuff, like butane, is near the top.
Somewhere in the upper ranges of the stack are the components of gasoline. There are between 10 and 15 different blend stocks, each with a different octane rating, which are mixed together to make gasoline.
The crude oil being used and little else determine the amount of each blend stock available for mixing. Generally, if you just dump all the blend stocks into a bucket, you end up with something around 88 or 89 octane. If you're selective and only mix the good stuff, you can make 92, 93 or even 95 octane. But once you take out the good stuff, you're left with crap--something like 85 octane. Then you have to leave enough good stuff in the bucket to bring this pee-water up to at least 87 octane. This limits the amount of 95-octane gas you can make. If you make 93-octane premium instead, you use up less of the high-octane stocks, allowing you to make a higher proportion of premium fuel.
In the Midwest, where an extensive customer base of good old boys in pickup trucks consume vast quantities of 87 octane, demand for premium fuel is low enough to make genuine high-octane premium.
In California, however, Lexus-driving executives suck down premium fuel like it's Evian, so 92 was the rule.
CARB isn't entirely innocent. Many of its standards for evaporative emissions and misdirected attempts at oxygenation have raised the manufacturing cost of high-octane gas, but it doesn't seem to be behind the sudden change to 91. Instead, according my super-secret oil industry mole, it all comes back to money. Unocal, you see, has a patent on the 173 easiest ways to make California-friendly 92-octane gas. As a result, every other oil company has to pay Unocal 5.75 cents for every gallon they make using one of these techniques. They haven't actually been paying it, but that's an issue for the lawyers to sort out.
Suddenly it's pretty obvious why our gas sucks, but why doesn't Unocal still sell us 92? Because it can't. In 1997, Unocal sold off all its 76 gas stations, and with them, its ability to decide what kind of gas to make. All Unocal can do now islook for oil, suck it out of the ground, and wish it had some way to make everybody else keep using its patents. You see, not only did Unocal screw us, they screwed themselves.
Ironically, the only gas stations in California with anything better than 91 octane are the ones Unocal used to own--the few 76 stations offering 100-octane race fuel. You can locate these elusive stations at www.76.com, but bring your wallet. The current going rate is $6.00 a gallon.
Unocal had the answer to the problem but ultimately no one wanted to pay them royalties to use it. So everyone else lost out with only 91 octane being available in CA as a result.No more 92: Premium octane rating drops in California
by JEFF SABATINI, autoweek.comOctober 17, 2001 07:00 AM![]()
While itâs hardly news compared to rolling blackouts, Californians are now dealing with another energy crisis: In August, the octane rating of premium gasoline in the state quietly dropped from 92 to 91.
For many, the drop in octane wonât make much of a difference, as most late-model vehicles that need premium fuel only require 91âand most will even run on 87, albeit with reduced performance when the knock sensor kicks in and retards the timing. Hardest hit: Owners of older, carbureted cars and trucks or those running hot-rodded engines; itâs hard to lower compression once youâve dropped in those flat-top pistons.
And the owners of Porsches with fuel filler flaps that clearly recommend 93 octane? Donât worry, your cars are designed to accommodate fuel as low as 91 (it says so in your ownerâs manual). And the difference between 92 and 91 isnât all that great.
âI donât think you will notice,â says Walter Lewis, Porsche senior compliance engineer. âOn a dyno you might, but it would be very minor.â
Okay, but what happened? Another Big Oil conspiracy? The work of the notorious California Air Resources Board? Well, as is anything involving energy and California, itâs complicated.
It started when Kinder Morgan, the company that owns the primary gasoline pipeline in California, surveyed its customers in April. Spokesperson Rick Rainey says Kinder Morgan asked over 100 refiners and distributors how the company could better serve them; nearly all of them asked to start running 91-octane premium through the pipeline instead of 92. On Aug. 1, Kinder Morgan made the switch. As the vast majority of gasoline sold in the state at some time travels through this pipeline, 92 in California disappeared as quickly as a Barry Bonds line drive.
So itâs that simpleâuntil you ask âWhy?â
First, thereâs the environmental angle. California Gov. Gray Davis banned the use of gas additive methyl tertiary butyl ether in the state by 2003. MTBE is a carcinogen that can leak into and contaminate ground-water, but itâs also the primary oxygenate additive that California refiners use in reformulated gasoline. It also boosts octane; thus itâs useful in blending premium gas.
The impending ban has created a widespread fear of gasoline shortages. According to Chevron repre-sentative Lou Gibbs, this is because the planned MTBE replacement, ethanol, cannot be added to gasoline in as high proportion as MTBE; thus the total capacity of the refineries will be reduced. The refineries are already running at full capacity today, says Gibbs, so the move to 91 is a step to stave off the perceived shortfall.
Of course, thereâs another side to the story, one thatâs more about money. In 1994, Unocal was awarded the first of five patents for reformulated gasoline, none of which use an oxygenate additive like MTBE or ethanol. Most major refiners are loath to license the formulas, as evidenced by a six-year legal battle over the validity of the initial patent, one that Unocal won. But, as Gibbs explains, Unocalâs patents for premium gasoline are for the 92-octane variety; 91 is not covered. Therefore, the switch to 91 may just be an end-around by the refineries to avoid paying licensing fees.
The story may not be over, though it seems likely Californians will have to live with 91 as the peak octane. Recent reports, however, indicate that the infrastructure necessary to handle ethanol in the required volumes doesnât yet existâand thereâs some question about whether ethanol can be produced in sufficient quantity to supply Californiaâs demandâso Gov. Davis may push back his 2003 ban on MTBE.
