Question: Charging the Battery
AGM mode... I don't have the product. Please read instructions. Nothing specific to Supra comes to mind. If it has modes or amps, lowest amp or winter settings.
Clamp it to terminals under the hood, not directly to the battery in the trunk...
legacy_etu
Brian
RI, USA
20 Supra, 16 Wrangler UNLTD
Sorry, can’t help as I have a Battery Tender brand.
puzzled
Calvin
I too just run a $25 Battery Tender Jr which automatically sets itself to AGM or lead or whatever the battery type that I am charging. I like to leave simple things to just plain simple. I'm too old to be reading tiny instructions manuals for this.
Hexel
Greg
Michigan
2021 Supra
great video
I’m storing my car using tire Flatstoppers.
puzzled
Calvin
My cars are currently on Flatstoppers too. Good stuff.
Lilchief
Louisiana
2021 Supra 3.0 premium, 2015 Corolla LE
I don’t really store my car... I drive it about once a week or so... is the ctek still ok to use in between drives? Also can I turn my car on while plugged to the ctek and then unplug it?
Lilchief
Louisiana
tomcxb
Tom
Mass
2020 Tungsten 3.0 Premium / 2020 Honda Odyssey Elite / 2018 Honda Civic Type R
I also use the CTEK and you want to set it to AGM
Lilchief
Louisiana
So can it be used btw drives? Also I have had mine plugged in for a couple of days but it never got to step 8 only 7.
tomcxb
Tom
Mass
It takes quite a while to go from 7 to 8 and it will cycle between the two as needed.
As for using it between drives, I don't know that you would need that unless the time between drives is many days. If so, then yes, it should be fine.
jchall30
KY
2021 Toyota Supra A91 Refraction 2021 Lexus UX250H
I posted this in another thread by mistake but this is my question. I know it has been discussed in multiple threads but what is the consensus on the best economical battery tender? I don’t drive mine but once a month during the winter to basically keep the battery charged and sounds like a tender is what I really need.
Lilchief
Louisiana
Should I unplug the ctek first and then turn on the car? Or turn on the car and then unplug?
