Is there a jack and lug wrench in the car? 2020 LE
sabrownfl
Shane
Central Florida
Bought used. Does the car come with one? If so, where is it stored? I checked the little cubby in the hatch and there is a screwdriver, and a little black device still in shrinkwrap. Am I missing something?
Nope. No spare tire. You get a tire kit which is that round cylindrical object on the right. That's how you fix a tire on the go.
sabrownfl
sabrownfl
Shane
Central Florida
Wow, not even a lug wrench? I will go buy one I guess, anyone know the size for factory lug bolts?
ky.supra
Kevin
A90 Supra
The black cylinder container is a tire sealant used to fix flats - I wouldn't use it as it has the potential to mess up your TPMS and it is a nightmare to clean when you remove the tire from the wheel.
The sealant is used with the tire inflator (square-looking) included in the cubby - which seems to be missing in your picture.
https://modernspare.com/product/2019-2024-toyota-supra-spare-tire-kit-options/
I bought this kit last year - saved myself and my other friend from a side wall cut on the stock OEM tires.
iirc 17mm socket to remove factory lug bolts
sabrownfl
sabrownfl
Shane
Central Florida
I guess BMW owners are to good to work on their own cars... No matter... I got the work done. New shoes mounted.
Reactions: zrk
consultadrone
Southern California
Should be a compressor in there as well so you can use the sealant. It’s not pressurized. Not that you would use any of it anyway but for the sake of completeness.
sabrownfl
sabrownfl
Shane
Central Florida
Yeah, no compressor. I drove an NC Miata for the last 17 years so I'm used to no spare, but at least I had a jack and lug wrench.
sabrownfl
sabrownfl
Shane
Central Florida
I didn't need a jack, it was more about learning what should have been in the car. And working on it is different than being on the side of the road without tools and needing to remove a wheel to get it repaired. Shit happens...
Bryan / Briana
Your moms bedsheets
I was replying to your snarky statement.
sabrownfl
sabrownfl
Shane
Central Florida
Yeah... I default to that a lot. Just playing on the tropes and stereotypes. No ill intent.
Reactions: zrk
