Oil Change Prices
Rocksandblues
Bob
You can debate the merits of money saved vs dealership warranty.... but if you do NOT know how to change your own oil, well... would not be impressed with you as a car guy/gal.
concept
Dave
Southern CA
Go easy on the guy gentlemen. This is a now era when they don't even have auto shop or teach drivers ed in schools, so all the masses know is to bring the car to the dealer.
The Supra uses the BMW B58 motor. I've got about 20+ years working on BMWs as a hobbyist guy.
So for the oil change you will need:
1. 2 gallon jugs of 0w-20 or 5w or -20/-30/-40 oil. Amazon sells them for around $30 each. Castrol or Mobile 1 are the brands I tend to buy. You'll only end up using 6.5 quarts but you can use the left over 1.5 quarts to top up if needed.
2. Mahle oil filter - The BMW dealer sells these pretty cheap as does Amazon. Around $15-$20. It will also come with a couple replacement rubber o-rings and an oil drain washer.
3. A wrench, I believe it's a 17mm to undo the oil drain plug. About $10-$15 from Home Depot
4. A rubber strap wrench to undo the oil filter cap, about $8-$12.
5. Oil pan - about $10-15 from Home Depot
6. Funnel - to pour oil into the engine and into the left over oil jugs, about $3-$8 from Home Depot
7. 8/10 gallon bucket - to pour the oil into, about $5-$10 from Home Depot
All in all, about $125 in parts and tools to do it the 1st time. After that, it's about $80 in oil & filters. Job is about 45min to an hour if you take your time.
How about the big socket for removing the oil filter?
Dannyvandelft
Danny
Ordered A91 edition Supra
Ok I just wanted to put my .02 cents worth to all you guys that have cars and want to save $100 at most by not using the dealer. If you do it yourself and not pay that labor premium ( dealer has a record if you do) and your car ever had a problem and you can’t document that you used the recommended oil, filter and related components, then Toyota can deny a warranty claim either in our outside of the original factory engine warranty. Not worth risking that to save a $100 bucks every 10k miles on a $60k performance car.
Nonsense. If a filter "fails" nothing happens. It just stops filtering. Oil is oil. It does what it supposed to. Only way it fails is if you don't change it in time, or let it run out the car.
This was my primary reason to bring it to the dealership. With my luck I would bring it elsewhere or try to do it myself and F it all up and there goes any warranty claim if it ever came down to it.
If you can tie your own shoe laces, you're qualified to change the oil on this car.
BrodoFratgins
Will
Florence, AL
2023 MKV Supra MT
Yeah pass. I'll save the $100+ and peace of mind of not letting the grifters that work at my local dealer touch my car again.
As long as you have the proper documentation of what you did, you're fine. People changing their own oil isn't a new thing.
ShakaDaKine
'21 TG 3.0
[/QUOTE]
He's using a strap, which would be difficult on the Supra.
concept
Dave
Southern CA
[/QUOTE]
I have 4 or 5 types of oil filter wrenches but no giant sockets. I'll have to buy one in a couple of years.
exe36m3
Percy
NorCal
BMW
Thanks guys, fixed my parts post, channeling my N55 motor says referring to the strap wrench!
puzzled
Calvin
My factory crush washer was stuck on the pan pretty good and for a second, looked like it was part of the pan. :crazy: This was 3 yrs ago.
