Burkano
- Thread starter
- #1
Hey everyone,
I’ve got a 2023 A91-MT, and I’m running a Catless downpipe, magnaflow exhaust, and a cold air intake. I also had the ECU partially unlocked by Femto and I’m running BM3 Stage 2 91 tune.
Currently my clutch is slipping when doing hard pulls and I need to replace the clutch.
Im trying to see what options I have for aftermarket clutches but from what I can tell the market is pretty limited. I’m not looking for a 1000 HP rated dual disk clutch. I’m looking for something to handle around 700 torque maybe at most, as I will probably only do flex fuel with port injection and E-85 tune.
I’m not tracking the car either so a spring clutch would probably be best from what I’ve been reading online
I’m looking for recommendations on opinions and options, or if someone has experience and can recommend something that would be great.
Also, should I do an aluminum or steel flywheel?
I don’t have any experience in this topic as I have never replaced a clutch for something aftermarket in any of the manual cars I’ve driven before as I left them all stock.
Thanks
Thanks
